5 speed endplate issue
Posted: Tue Jul 02, 2013 7:10 pm
by sydduckett
Putting a cyclone together and im struggling to get the end plate bearing over the christmas tree. Iv given it some light force but its way to tight really. I could give it a bit more of a whack and get it home but id never get it off. anyone else had this issue?
Ta
Sef
Re: 5 speed endplate issue
Posted: Tue Jul 02, 2013 7:27 pm
by dutch
yeah had the same problem but just used a plastic hammer and tapped it on, if you use the bolts to get the end plate off and plastic hammer to tap the xmas tree back now and then it does come off.
Posted: Tue Jul 02, 2013 7:37 pm
by sydduckett
Im so tempted to give it a whack but the end plate has always been a tight fit so im concerned that if i do whack it home, there it will stay.
I guess i need a couple more people to say the same and ill get my hammer out....
ta
Posted: Tue Jul 02, 2013 8:13 pm
by soulsurfer
How did you get the layshaft in? It does take a little persuasion
Posted: Tue Jul 02, 2013 8:17 pm
by sydduckett
soulsurfer wrote:How did you get the layshaft in? It does take a little persuasion
well i gave it a couple of whacks with a plastic hammer like you do. Thing is i can get that back out if i have to the end plate may be a different bag of onions though.....
Posted: Tue Jul 02, 2013 8:26 pm
by john.t5
I used a real hammer
Did have it on and off a few times though so no probs.
Posted: Tue Jul 02, 2013 8:34 pm
by sydduckett
john.t5 wrote:I used a real hammer
so it was tighter than a normal set up? Feel the persuader is about to make an entrance.....
Posted: Tue Jul 02, 2013 10:17 pm
by dave wheeler
mine was definitely tighter than usual, put the nut on the xmas tree before you attack it though
