Malossi 210 kits - 2013 redesign
Posted: Tue Jul 02, 2013 1:37 am
Anyone have more info on the redesigned Malossi 210 kits? Scooter center sent out some info but it would be nice to see some pictures of the bores and some port timing numbers. Here is what they put out:
http://blog.scooter-center.com/malossi- ... 0/?lang=en
Two new Malossi Cylinder vor Vespa 200cc
1983:
The Malossi aluminum cylinder with 68,5 mm diameter for Vespa 200 – turning point in Vespa tuning – was born. Made of Nicasil aluminum, with super light piston and 1.2 mm semi trapezoidal rings, it becomes a legend, a real must-have for all Vespa fans.
2008:
The Malossi Vespa cylinder is updated, by adding the head with hemispherical combustion chamber and central spark plug.
2013:
The cylinder, always made of Nicasil aluminum, has been completely changed concerning both main and rear ports and exhaust port as well. Exhaust port will be available in
Two versions:
- SPORT: Art. 3115618
- MHR: Art. 3115567
MHR version is different from SPORT version also due to the port map with racing features.
The perfect centering between head and cylinder is guaranteed by two centering bushes located on two stud bolts, while the o-ring ensures a perfect seal.
TECHNICAL FEATURES
ALUMINIUM CYLINDER
- Cylinders obtained by gravity die-casting in permanent steel moulds.
- Material: hardened and tempered high silicon content primary aluminium alloy.
- Machining: on numerically controlled high precision machine tools.
- Cylinder liner with silicon carbide metal-spray coating on a galvanic nickel matrix, cross-honed with passes with diamonds for very tight tolerances.
- Recalculated and increased heat exchange surfaces.
- Exhaust and transfer ports designed and tested for maximum thermodynamic performance.
- Dimensional and surface finish quality control performed according to Malossi’s internal specifications.
- Cylinder and piston selected for a fit of 0.005 mm.
- Checking of all the seals carried out.
1983:
2008:
2013:
Two versions:
- MHR: Art. 3115567
TECHNICAL FEATURES
ALUMINIUM CYLINDER
