Vesp PK50 Help
Posted: Mon Jul 01, 2013 10:21 am
Good Morning,
I've just finished building a Vespa PK50 with a Malossi Kit on, and I'm having real difficulty tuning the carb. My setup is below. I'd appreciate any help you can offer, and a standard routine for tuning, as I can't even get the scoot running well at the moment.
The setup is;
PK50 Casings, not ported.
Malossi 136 Kit,
Dellorto PHBL 25, with AQ266 atomiser, D22 needle, 50 slide, 95 Main, 42 Idle, 40 pilot
Simonini Down and Forward exhaust.
I have a selection of Jets, slide and needles to try, and I have tried Main jets from 115 down to 90, idle jets from 40-50. the 42 idles and start well. The 95 main is ok when the scoot is stationary, but when I take it for a test ride, the pick up is slow, and it dies when i ride it uphill. I've tried a 40 and 30 slide, but they are worse, similarly, a D26 needle is worse.
I've checked all the obvious fault finding stuff, like fly seal, air leak, timing, etc all are ok, so I'm convinced its the carb.
I was hoping you could find the time to have a read through and perhaps recommend a course of action. I feel I'm at the edge of my knowledge.
I appreciate any help you can offer,
Kind Regards,
Dan
The setup is;
Malossi 136 Kit,
Kind Regards,
Dan
