Nyloc
Posted: Sun Jun 30, 2013 6:23 pm
by bishopsfinger
Hi all,simple question.Nyloc cylinder head nuts or not? My malossi 210 vibrates so subsequently everything loosens!
Re: Nyloc
Posted: Sun Jun 30, 2013 10:05 pm
by gaz_powell
No
Use a thick flat washer, good quality spring washer and a deep nut
Torque it up to 17lbs/ft
Re: Nyloc
Posted: Wed Jul 03, 2013 10:19 pm
by bishopsfinger
Cheers mate
Re: Nyloc
Posted: Tue Jul 16, 2013 9:09 pm
by AUSSIE
try stover nuts or philidas nuts. both are all metal self locking nuts.
http://www.orbitalfasteners.co.uk/en/ca ... tover-nuts
Re: Nyloc
Posted: Tue Jul 16, 2013 9:27 pm
by Muttley McLadd
Have you looked into why it's vibrating so much?
Re: Nyloc
Posted: Wed Jul 17, 2013 12:00 am
by Juan
Standard or aftermarket crank?
Aftermarkets tend to be shite so if so good chance it's out of kilter.
Re: Nyloc
Posted: Wed Jul 17, 2013 8:31 am
by goldeneye
use a flat washer, a spring washer, and I use 4 of the longer headcowling distance nuts instead of the normal nuts, torqued to 18 ftlbs.
Re: Nyloc
Posted: Wed Jul 17, 2013 8:54 am
by bristolmod
as I understand it you should never use "Nyloks" or similar self locking nuts on studs that are in alloy. The nyloks/ self locking nuts can lock so tight that it unscrews the thread rather than just the nut.
As stated above- flat washer; locking washer; then plain nut.
Chris
Re: Nyloc
Posted: Fri Jul 19, 2013 2:01 pm
by shocky
goldeneye wrote:use a flat washer, a spring washer, and I use 4 of the longer headcowling distance nuts instead of the normal nuts, torqued to 18 ftlbs.
and drill them them with 2mm holes both sides and use locking wire
Re: Nyloc
Posted: Sun Jul 21, 2013 9:09 pm
by bishopsfinger
Hi all and thanks for your help,found rogue cylinder stud,longer than the rest it had a dodgy thread atthecasing end and ws working loose
