electrical fault
Posted: Sun Jun 23, 2013 1:42 pm
my serveta 150 special still running on motoplat 6volt electrics has just developed the following fault.
engine runs fine but ive lost the use of indicators,main and dip beam and brake light.
by isolating various bits ive established that the pilot light and tail light work until you hit the light switch or brake switch then they also go out,but the brake light comes on eventually but slowly and without much power,the horn tries to work but cant quite make it,fire up the motor and there is no noticable differance,similarly bypassing the battery (which is new) and shoving 6 volts up it direct from the mains makes no differance.
I cant find any obviosly damaged wires or earth connections and am begining to suspect the stator or regulator.
anybody got any advice please
Sledge
Sledge
