Page 1 of 2
Ram air filter advice
Posted: Sat Jun 22, 2013 8:30 am
by retrorich
Currently running Muggy 225-fast road tune with 30mmphbh, JL3. It has always been fitted with ram air filter. Due a filter change. I hear that LTH foam filters are better. Never used them but think that the ram air foam filter does struggle to get air in enough because it is positioned between filter box and petrol tank. Is there a better alternative?
Re: Ram air filter advice
Posted: Sat Jun 22, 2013 8:39 am
by thebassmasta
Why would it struggle to get air in? Have you got the air scoop fitted under your seat?
Posted: Sat Jun 22, 2013 8:59 am
by Angry Bloke
I'm running a Marchand filter on an Avanti ,which seems OK but was wondering if there is any thing better out there so Ill watch this thread with interest
Posted: Sat Jun 22, 2013 9:36 am
by retrorich
Yes I have a baffleless airscoop. I think the point I am trying to make regarding air intake is that these filters lose there effectiveness in a short space of time and the foam seems to harden. The scoot is running rich and probably needs a change of foam anyway. At £30 a pop these are not cheap. If there is a better alternative I am interested in what anyone thinks. The scoot covers around 2k miles a year and I would expect to get more serviceable use out of a filter than having to replace each year.
Posted: Sat Jun 22, 2013 10:00 am
by cezeta
best flowing filter is the breath sweet from cam lam. proven on the dyno on my bike to have pretty much no negative effect on power over a open carb. the others we tried had a huge effect and needed re jetting to suit.
you may need to fit a coil of coat hanger wire inside to stop it flattening though as they soften with age and heat and can close up
Posted: Sat Jun 22, 2013 10:55 am
by Adam_Winstone
^... Exactly as Cezeta says. I now only use my larger remote RamAir filter on a standard iron 175, whereas I'd only use my smaller RamAir on a 125/150, even though it was supplied by a well-known dealer/tuner for 200cc use. The restriction posed by the filter was staggering, going bigger helped but going to Breathe Sweet was different again
The only issue is that I've not been happy with the fit/space of the hose that comes with the Breathe Sweet so have used them with standard air hoses.
Adam
Posted: Sat Jun 22, 2013 2:08 pm
by Angry Bloke
Sorry to hijack Retrorich but ,Adam do you think I could fit a Breathe Sweet in here ?
Posted: Sat Jun 22, 2013 2:50 pm
by Adam_Winstone
Not upright but you might manage one back towards the rear strut.... might.
Posted: Sat Jun 22, 2013 2:57 pm
by retrorich
Thanks guys. Just one more daft question. Given that I cover 2k miles on this scoot, when should I expect to have to change the foam filter? I think less than a years use and approx 2k miles covered is a poor return. Surely they are good for longer.
Posted: Sat Jun 22, 2013 3:21 pm
by Angry Bloke
retrorich wrote:Thanks guys. Just one more daft question. Given that I cover 2k miles on this scoot, when should I expect to have to change the foam filter? I think less than a years use and approx 2k miles covered is a poor return. Surely they are good for longer.
It should be ok - I would just give it a clean
