Kickstart sticking.
Posted: Fri Jun 21, 2013 9:35 pm
by Ihateyoubutler
When I start my jet 200, the kickstart sometimes stays down. A gentle nudge up with the foot brings it back to the the correct position (against the buffer stop). Before I take the sidecasing off, anyone have any pointers as to what to look for as to what's causing this?
Thanks.
Re: Kickstart sticking.
Posted: Sat Jun 22, 2013 8:37 am
by wack 63
Wear on the ramp or index pin ?
Posted: Sun Jun 23, 2013 4:23 pm
by bristolmod
its not anything simple like the buffer stop protrusion hitting the exhaust when its floored is it?
Posted: Sun Jun 23, 2013 8:27 pm
by a.lo.v2
have had the problem bristolmod said on a clubman tailpipe,a persausive mallet did the job. but another to look out for if you have changed kickstart shaft or reference pin is that it (the pin) sticks too far out and i have a gouge out of the nearby stud housing in the crankcase
Posted: Sun Jun 23, 2013 9:22 pm
by Ihateyoubutler
Thanks for the replies, I'll be looking at it tomorrow. It's definately not the kickstart catching on the tailpipe, so I'll have a look inside.
Thanks again.
Posted: Sun Jun 23, 2013 9:44 pm
by Muppet
Wen its off chek y bush that sits in sidecase were y shaft sits it can move out and push aginst y kick shaft makin em stick a litle
