speedo wiring
Posted: Fri Jun 21, 2013 8:51 pm
Dumb question. Does a black run from the speedo bulb holder screw to black on bulb holder and the earth just poke up when bulb goes in. Its the black feed i seem to have overlooked. Thanks
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
Thanks for that. That explains why there is a screw fitting on bottom of speedo bulb holderwack 63 wrote:Take a feed to the speedo bulb from a black on the headlight junction box, then run an earth from a headset control rod bridge and either solder it to the speedo bulb holder or trap it when you fit the holder in the speedo.
