Avanti and TM24
Posted: Thu Jun 20, 2013 12:28 am
by ScooterLoopyJohn
Hi Avanti with a 60 stroke and 24TM carb and air box . 185 main 22.5 pilot needle 5n13 top clip very close to perfect. will repost after dyno
Re: Avanti and TM24
Posted: Thu Jun 20, 2013 7:57 am
by Agent Buchwald
Interesting to see if it acts as a restriction anywhere - could you post with what Ron would expect from the same engine with say a PHBH 30mm or whatever he recommends?
Re: Avanti and TM24
Posted: Thu Jun 20, 2013 10:40 am
by Adam_Winstone
Watching with interest :)
Re: Avanti and TM24
Posted: Fri Jun 21, 2013 7:24 pm
by OAP
Me too
Re: Avanti and TM24
Posted: Fri Jun 21, 2013 8:09 pm
by drunkmunkey6969
Ditto
Re: Avanti and TM24
Posted: Fri Jun 21, 2013 11:34 pm
by Honeymonster
What exhaust are you using SLJ? top clip on a 5N13 is usually lean but what atomizer are you using?
I'm running the TM24 on a 60 crank with an RT 220, breath easy filter, LTH stage 6 reed valve and MB clubman, current setting are, 25 pilot, P8 atomizer, 5N13-3, 3mm slide and 200 main but still running in the high 600's, have been looking at a low compression head from Mark to look for more cool running.
Will be interested in your dyno results.
Ian
Re: Avanti and TM24
Posted: Sun Jul 21, 2013 6:28 pm
by mick1
Any updates ??
