Vespa SI Slides
Posted: Wed Jun 19, 2013 1:44 pm
Having looked and altered everything in SI carb (caps, needles, filters etc) - i started looking at slides
P200 24mm and 26mm uses 8492-4
T5 24mm uses 8492-5
Found this on the net
The Si 24mm carb. has two types of throttle slide. The Si E found on the PX200 has smaller cutouts compared to the slide on the Si G carb. found on the T5. The throttle slide cutouts allow air to pass through and mix with the fuel at idle. The T5 G carb. with it's larger cutaways allows more air in at idle compared to the Si E cutaway. This will also have some effect on takeoff as it will enable more air in and hence with the jetting, more fuel. This is the reason why the Si G carb has a richer idle jet than the Si E carb.
Reading the above would say that an increase in pilot is required if the T5 slide is used - has anyone done it and what effect ?
Gaz
T5 24mm uses 8492-5
Gaz
