Page 1 of 2
Anyone running RT 195 MB/BGM kit?
Posted: Sun Jun 16, 2013 1:36 pm
by Mike - - Bristol
I was about to choose between Mugello 200 and an Imola when someone recommended the MBD RT 195 kit but I don't know much about it.
MB stuff is usually pretty good, it's ceramic lined apart from that nothing.
Anyone running this kit could give me some info or recommendation? I have a AF Clubman or PM pipe to choose from and a 26mm Delorto.
Be grateful for any feedback.
Re: Anyone running RT 195 MB/BGM kit?
Posted: Sun Jun 16, 2013 1:43 pm
by thebassmasta
no there not ceramic lined, the new batch is nicasil lined, ive been warned not to use the 26mm delli
http://www.lambrettaspares.com/info/lam ... rs+61.html
Posted: Sun Jun 16, 2013 1:58 pm
by Mike - - Bristol
Why is the 26mm PHBH I have a problem, I want to keep any cost to a minimum (after the kit) , also reading the link they said Ceramic was preferred so why go back to Nicasil , not that I mind that .
Posted: Sun Jun 16, 2013 3:16 pm
by dutch
according to bgm site there ceramic lined
http://www.scooter-center.com/product/B ... R_ZYLINDER
Posted: Sun Jun 16, 2013 5:27 pm
by purple_pill67
The MB/BGM Kit should be ready to ship later this week, the UK made MB kit has been out awhile.
Posted: Sun Jun 16, 2013 6:01 pm
by thebassmasta
I have read an article from Mark himself, it is defo nicasil lined, original plans where to ceramic line, please see the quotes from MB website.
"This late sample batch has the MRB marking, UK early ones had MBD"
"Shinny hard Ceramic plated in the UK, the later versions use a Nicasil plating"
As regards to the carb this is part of an email I received from Mark and I would tend to agree with him
"I don't use the 26mm carb its a waste of time in between carb, I would go for the 25mm if you want standard looks and the air filter boxes. Or I would use a 28 or 30mm on the down draft manifold. At the moment we are out of stock but they are ordered. Both kits need a 200 inlet manifold. Should only take a day or so to do the inlet, but I guess a few will want it done as its a great way to get the kit going."
Posted: Sun Jun 16, 2013 6:06 pm
by thebassmasta
also go to the tech tab on this page
http://www.lambrettaspares.com/spares/c ... 0261k.html
Posted: Sun Jun 16, 2013 8:07 pm
by thebassmasta
Technical
CNC machined.
Nicasil bore.
Uses MBgm Race-Tour piston at 65mm.
Gives around 10hp with 22mm carb and Clubman exhaust.
Gives around 15-19hp with 24/25mm carb and Clubman exhaust.
Gives around 16-19hp with 30mm carb and Clubman exhaust.
Gives around 18-20hp with 30mm carb and MBgm Big Box Clubman exhaust.
Available with normal 39mm crown height pistons to suit 107mm or 110mm con rods.
With the use of different base/head gaskets/packers port timings are adjustable to suit Touring or Road-Race use.
Posted: Sun Jun 16, 2013 8:50 pm
by Mike - - Bristol
Do they still do the original one? Can't see it on the site.
Posted: Sun Jun 16, 2013 10:46 pm
by thebassmasta
no, The new kits are in stock this week and are all manufacured in germany,
check this out
https://www.facebook.com/media/set/?set ... 864&type=1
