End plate problem
Posted: Sun Jun 09, 2013 11:10 pm
by biddy
Hi I have a couple of end plate studs rung is there anything other then wielding and taping again any advice would be greatful ;)
Re: End plate problem
Posted: Sun Jun 09, 2013 11:22 pm
by joespeed
heli coil
Posted: Sun Jun 09, 2013 11:52 pm
by john.t5
Got mine helicoiled, think £20 for 3, you can buy the kit to do it yourself but it's about £35, I've M6 kit, great job.
Posted: Mon Jun 10, 2013 4:57 pm
by biddy
The studs are m7 /28mm should the helicoil not be m7
Posted: Mon Jun 10, 2013 5:10 pm
by sean brady scooters
"Time -serts "are far better :D
Posted: Mon Jun 10, 2013 6:19 pm
by bsso78
Like Sean said.
If you want a thread repair thats as strong as stuffing the hole with chewing gum and then winding a stud in, use a helicoil.
Posted: Mon Jun 10, 2013 6:48 pm
by biddy
I saw beedspeed do a m8 step down to m7 in other words tap out to m8 has one used these before any good
Posted: Mon Jun 10, 2013 8:45 pm
by TED CRUD
sean brady scooters wrote:"Time -serts "are far better :D
yup much better !
