Lost 2 wheel studs
Posted: Sun Jun 09, 2013 8:34 pm
by vRSG60
Had a quick 25 mile drive before tea. When I got home and was pushing the scooter I could here a knocking noise. Turned out I'd lost 2 rear wheel studs and the wheel was loose on the other 2
The thread in the hub has stripped on one stud position. Can the new stud still be torqued up as normally when fitted? I guess the studs are only there to help fit the wheel and it wouldn't make any difference if they were studs or bolts.
Re: Lost 2 wheel studs
Posted: Sun Jun 09, 2013 9:27 pm
by Monty
Having been in the position of losing 3 on the IOW last year I would warn against taking any risk. You only have 4 bolts holding your wheel on, Only last week I sheared a stud after changing the wheel on my other scooter and looking at the remaining studs I was very surprised at how thin the bolts were at the transition from 8mm to 10 (or is it 11) I opted to replace the lot, Yes a bugger to get the old ones out but double nutting worked. Not having a good solid hold on the hub would worry the s*** out of me. I would also check your rim and replace that if it shows any sign of elongated holes. I opted for an SR SIL hub and spent an evening in front of the telly with a small file removing all the flash seams off the casting and its as good as the original.
Posted: Sun Jun 09, 2013 9:34 pm
by lambro
Never under estimate the importance of those little insignificant rear hub studs.
My mate Aitch found out ignoring a little knock, led to something a little more serious.
Unfortunately we didn't find the cause of the little knock until this:
Then it was blatantly obvious what the rattle was, when his rear wheel sheared and sent him and his female pillion airborne last year.
Posted: Mon Jun 10, 2013 12:58 pm
by vRSG60
New wheel and studs on order. I've got some "thin" lock nuts so I'll use these with standard nuts locked together and "shakeproof" washers instead of Nylocs.
