jetting help please
Posted: Thu May 07, 2009 7:08 pm
by barneypeter
been advised to downsize my carb from a 34 vhsb to a 30phbh ,its fitted to a 190 challenger kit with rd 350 reed block with a scootrs pipe at present ,any help would be good and to be slightly rich as running in with new piston cheers chaps
Re: jetting help please
Posted: Fri May 08, 2009 11:07 pm
by J1MS
barneypeter wrote:been advised to downsize my carb from a 34 vhsb to a 30phbh ,its fitted to a 190 challenger kit with rd 350 reed block with a scootrs pipe at present ,any help would be good and to be slightly rich as running in with new piston cheers chaps
Its a fairly rare setup these days...your best bet is trying to contact Harry Barlow, or maybe Martin Cooke at Chiselspeeds there probably best equipped with the answers.....Im sure someone on here will have an Idea....... but I wouldnt know where to start without seeing the state of tune of the barrel... transfere's, Exhaust, Inlet, and compression ratio....sorry :?
Posted: Tue May 12, 2009 9:54 pm
by barneypeter
thanks jims ,harry supplied new parts been trying to ring but hard man to get hold off he is really quite chuffed i think theres still one on the road it was he who said change to a 30mil ,will keep trying him cheers peter
Posted: Thu May 14, 2009 8:35 am
by Special X
try 52 idle
AV266 atomiser
X13 needle (X7 if this too rich)
128/130 main
Should be on the rich side of the ballpark for safety so you can have it dynoed to dial it in.
