series 1 150 to 175 conversion ?
Posted: Sat Jun 08, 2013 4:27 pm
by tea5ive
can I use an early series 1 150cc cylinder for a 175 conversion ?
Re: series 1 150 to 175 conversion ?
Posted: Sat Jun 08, 2013 4:29 pm
by RICSPEED
you could but arn't series 1 barrels shorter ??
Posted: Sat Jun 08, 2013 4:35 pm
by tea5ive
RICSPEED wrote:you could but arn't series 1 barrels shorter ??
yes ric, that's why I am asking
Posted: Sat Jun 08, 2013 4:53 pm
by RICSPEED
tea5ive wrote:RICSPEED wrote:you could but arn't series 1 barrels shorter ??
right ,well id have to assume then that a 175 conversion piston is going to be too long without packers and such like ,you would probbably be better off with a series 2/3 barrel
Posted: Sat Jun 08, 2013 5:51 pm
by tea5ive
probably easier as you say to use a series 2 or 3 cylinder . just built up a series 1 150 frame breather engine and wanted to use as much as I could of the original engine but also give a bit of an upgrade. put a mec ure gp crank in with a 60 stroke( that's what I had on stock) so that would not have made it any easier with a short cylinder. I have also added an electronic ignition. I have lots of cast cylinders so will find a series 2 or 3 150cc to rebore to 175 or 185. put a wanted add out for a top end kit but the offers I received were all too good for this as I will be selling on once finished, don't think I would gain any more cash if put on a mugolla or gt etc. also the cost of rebore + head re-profile and piston kit bring you into the realm of the ebay cheapo cast/ally sr type kits.
Posted: Mon Jun 10, 2013 6:04 am
by johnd
Series ones pistons have the same compression height as a tv175 piston, 30mm, so yes you can bore out a series one cylinder to 175 if you use one of these pistons. You can also use a Suzuki TS185 piston and have 186cc.
Posted: Mon Jun 10, 2013 12:02 pm
by Solerunner1
Yeah, i was gonna say the ts185 route too. The series 1 barrel allows for a more milder tune than the standard short cylinder version. And you have the option of higher quality pistons. You will need a 1mm or so packer though. The wiseco pistons are solid and reasonably priced.
Posted: Mon Jun 10, 2013 12:11 pm
by tea5ive
that sounds a good conversion using the origional cylinder . what year of ts 185 or part no do i need, and cheers for the help. simon
Posted: Mon Jun 10, 2013 9:13 pm
by johnd
Beed speed sell the correct piston for about 35 quid. You might need to shorten the skirt of it too, not exactly sure by how much.
