Gearbox end plate bearing
Posted: Tue Jun 04, 2013 9:12 pm
by bazza3004
Hi . going to replace the end plate bearing (the one for the cluster) and just wondered how tight a fit they are. Could i apply some heat and tap it out / in or will it require a press. thanks.
Re: Gearbox end plate bearing
Posted: Wed Jun 05, 2013 12:10 am
by rosscla
Some heat and tap it out, usually not that tight.
Posted: Wed Jun 05, 2013 12:53 am
by bazza3004
Thanks for that.
Posted: Wed Jun 05, 2013 10:19 pm
by bazza3004
swapped it for a new one today . as you said bit of heat and it tapped out / in no problem. thanks again.
