Indian gp headset internals
Posted: Tue Jun 04, 2013 6:55 am
by simonwwfc
Will all the internals from my Indian gp headset fit into my Italian drops . I.e handle bar throttle tube , rods , etc
Re: Indian gp headset internals
Posted: Tue Jun 04, 2013 8:02 am
by rosscla
Maybe. Like anything else you won't know till you try.
Posted: Tue Jun 04, 2013 11:40 am
by simonwwfc
Anyone else as if I need to order parts I need to in next day or so .
Posted: Tue Jun 04, 2013 3:10 pm
by RICSPEED
all the rods ,pullies ect yes .. or rather they should ..
did you get some italian type clutch and throttle lever supports as i seem to recall you had the larger indian ?
Posted: Tue Jun 04, 2013 10:29 pm
by simonwwfc
Yes bought new gear change and lite switch housing to take master cylinder .
Posted: Wed Jun 05, 2013 12:14 am
by rosscla
simonwwfc wrote:Anyone else as if I need to order parts I need to in next day or so .
So get on with trying the old ones to see if they fit or not... :roll:
Nobody here KNOWS for sure, could be your drops are cast wonky.
Posted: Wed Jun 05, 2013 6:48 am
by simonwwfc
look my drops are in paint shop . i was asking a simple question so if i needed to order new parts i could get them sent by time drops will be painted . it seems to many on this forum are quick to jump on peoples post :x all it needed was a straight forward answer :roll:
Posted: Wed Jun 05, 2013 11:47 pm
by rosscla
Look yourself, I gave you the straight forward answer first post. The fact is nobody on here KNOWS what bits will fit. Doesn't matter how many times you ask. All folks can say is what MIGHT fit or what OUGHT to fit. The number of opinions you get doesn't swing the balance one way or the other and won't make them fit.
Imagine I asked if I can fit into an XL tee shirt? How would you know?
If you ask will vespa wheel rims fit on my GP the we could probably say 'no' but as always the caveat would be 'unless you fitted Vespa forks.'
