Ts1 top end build
Posted: Mon Jun 03, 2013 5:19 pm
Hi all, looking for a bit of help when it comes to building up my ts1 top end & using a packer plate.
I've just uprated my crank to a 58x110 yam rod which requires the use of a 3mm packer plate at the base. I'm in the process of setting the correct squish but before I bolt it all down my question is with regards to the packer plate.
Does the plate require a gasket either side or do you install the plate without any gaskets
If installing without any gaskets then I'm concerned that this wont provide a good enough seal
If I need to install the plate without gaskets then I was thinking of using loctite 5920 at the base, I assume this will be ok
Also if the squish requires no head gasket would the same loctite 5920 be ok or the head
Help much appreciated.
Mike
Mike
