Rear Hub NUT GP on SIL engine
Posted: Thu May 07, 2009 7:54 am
by vespinello
Hello,
Do you know if the rear hub nut does exist in different dimension?
Here below my problem
Original Nut from my original LIS engine
Original nut + fixing kit for SIL hub
I can't fix the hub....i have too many space between the hub and the nut
What esle
Re: Rear Hub NUT GP on SIL engine
Posted: Thu May 07, 2009 7:56 am
by mark
is the cone shim on?
Posted: Thu May 07, 2009 8:07 am
by vespinello
Cone shim = part nr 20 ?
Yes it 's on...but i'm not sure that's the orginal one...the shim that i use is 1mm thick...
Posted: Thu May 07, 2009 9:21 am
by Soulpunk
don´t use grease there.
for the nut, there are nuts with a deeper head. also had that problem on some scooters.
essential also is the cone. there are 3 different types of angles. the angle in the rear hub and the cone you use must be the same. its absolutely essential.
Posted: Thu May 07, 2009 9:23 am
by simon
Barry Turner at scooter warehouse sells the longer threaded nut, if that’s what you need
Posted: Thu May 07, 2009 11:43 am
by vespinello
Ok thanks for your help..i 'll try with a longer nut
Posted: Thu May 07, 2009 1:48 pm
by eibargum
I,d try it with a normal nut [not domed] first and if all,s well get a deeper one, simples
Posted: Thu May 07, 2009 1:52 pm
by RBG
No 20.
