very weak spark what next ?
Posted: Fri May 31, 2013 1:15 pm
by rbgaz
changed stator for new one , have checked it out with multi meter all good, have put new coil on,changed ht lead ,caps plugs, still the spark is so weak i cannot myself even see it, only thing i havnt changed is flywheel as i havnt one to hand, any advice welcome cheers p.s the scoot starts first kick but runs like bag crap when u take it for a spin
Re: very weak spark what next ?
Posted: Fri May 31, 2013 1:59 pm
by coaster
Was it running allright before the stator change or was that the reason for changing it? Are the lights working ok? If the lights are bright then I would think that would rule out a de-magnetised. What makes you thin k it's an electrical fault?
Posted: Fri May 31, 2013 5:23 pm
by rbgaz
yes broke down at jb tuning and his meter said it was dead , new one on and same troubles, lights are very good,,it might not be elecy fault just trying every thing i can, ive put new needle in carb plus jets its a tm 35, new carb rubber etc new reed petals, only really got two more things to try if its electrics a diffrent flywheel if carb new slide maybe
Posted: Sat Jun 01, 2013 12:27 am
by Yanker
rbgaz wrote:runs like bag crap when u take it for a spin
I have it on good authority that this is a normal ,typical and in no way unsymptomatic prevarication of the Lambretta marque: enjoy it while it lasts!
Posted: Sat Jun 01, 2013 12:37 am
by Yanker
It' posibly your pick=up to fly wheel trigger alignment then?
Posted: Sat Jun 01, 2013 12:41 am
by Boothy_the_makem
my mate had a similar problem, wouldn't start and had changed everything, , asked him about the plug and he had 3 or 4 new ones,
took the plug out of my gp and put it in his , fired up first kick,
3 or 4 dodgy new plugs,
Posted: Sat Jun 01, 2013 1:39 am
by Bufficus
Boothy_the_makem wrote:my mate had a similar problem, wouldn't start and had changed everything, , asked him about the plug and he had 3 or 4 new ones,
Always check plug first. Cap then lead.
Have you just filled up with crap fuel? BP high octane at Boreham interchange is often dodgy
Posted: Sun Jun 02, 2013 12:29 am
by Boothy_the_makem
Bufficus wrote:Boothy_the_makem wrote:my mate had a similar problem, wouldn't start and had changed everything, , asked him about the plug and he had 3 or 4 new ones,
that's what he did. and went through 3 or 4 plugs. all dodgy
quite often im pissed, like tonight, but I usually take the time to process other peeps posts
Posted: Sun Jun 02, 2013 12:54 am
by blue
If you haven't already tried it, unplug the green wire from the loom to cdi to rule out an ignition switch fault.
