I rarely get to dabble with Vespas but I do occassionally cross over and get my hands dirty, whether it be sorting out a mate's ignition timing or other general scooter issue. However, I have a French mate staying with me at the moment and he brought his T5 top end with him so we decided to inspect it.
With the T5 being such a great performer for its size, and dabbling with Lambretta tuning, it had always had me scratching my head how the T5 could run 11.3:1 geometric compression ratio, whilst not holing pistons
Geometric compression ratios might be easy to calculate and give you a ballpark figure to have some sort of idea, however, when considering compression ratios on 'tuned' motors, geometric ratios actually mean very little! As compression cannot start until the exhaust port closes, the trapped charge compression ratio (corrected compression ratio) becomes the only real way to assess a ratio, rather than 'guessing' how a head might perform with a geometric ratio. Now, considering that the Vespa tech specs list 11.3:1 geo.... and also list the T5 as only having 170 + or - 2 degrees exhaust port duration, it seemed to me that the corrected ratio would be high too, making me wonder how the T5 manages not to hole pistons
Well, after we had both (independently) measured the volume of the combustion chamber, calculated the squish volume (as we know it to have a 1.3mm squish when assembled), we set about calculating the geo and corrected volumes of this 100% standard motor.
WOW
We were both surprised by this error, even if it tuning theory suggested it should be wrong, so we double checked our volumes, calcs and also double checked the head for signs of being reworked... only to come to the same conclusion that the Vespa figure IS wrong.
Anyone else come across this issue?
Adam
