casa rear bearing
Posted: Sun May 26, 2013 4:48 pm
by dave wheeler
just bought a Spanish 200 casing fitted with a casa rear bearing, I believe there are some issues with this and was wondering how can you tell the good ones from the iffy?
regards
Dave
Re: casa rear bearing
Posted: Sun May 26, 2013 6:50 pm
by RICSPEED
not sure if its the casa ones but if i recall correct some are slightly wider causing gearbox shiming problems
Posted: Mon May 27, 2013 8:29 pm
by Yanker
Yes, bearing case was too wide on a batch: cannot shim withouth 1.0 + shim selecton. All
the ones I have bought since 2006 have been A1
Posted: Tue May 28, 2013 6:28 pm
by dave wheeler
do you mean the bearing case, ie the height, was wrong, if so is there any way to tell which one ive got?
regards
dave
Posted: Tue May 28, 2013 6:48 pm
by RICSPEED
yes the bearing case ... if you have an orriginal one to compare with vernier calipers
