series 1 engine case and mag flange
Posted: Sun May 26, 2013 11:27 am
upgrading a series 1 li150 engine to electronic and gp crank and a rebore to 175cc. I take it I can use the original mag flange with the nu2205 bearing ? . is there anything else I should be aware of ?. also the gear box is an early 125 would this be ok to use ( 175, clubman and a phbh 28mm) ?. I should know all this but have had a bout of brain fade
. cheers simon
