Inlet Manifold - problem!
Posted: Fri May 17, 2013 9:06 pm
I seem to be having problems with every bit I try to assemble on my build - getting a bit tedious to say the least.
Anyway -- I built my engine and when doing so I sealed the inlet manifold with a silicon gasket. Engine is now back on the frame, and when I was looking at the carb I notice that the diameter of the carb outlet (36mm) is less than the manifold diameter (40mm).
Appears I have the wrong manifold -- didn't even think about this when I put it on. So I can take it back and change it but.....
I seem to have done a really good job in sealing it as it don't want to come off tried soft mallet persuasion but no good. Given that I want to exchange it I need to be careful with it.
So I either persevere and try and get it off or I leave it on and use a stepped rubber (I think beedspeed do them)
If anyone has suggestions on how to break the silicon seal that would be great or......... are there any issues with using a stepped rubber?
Thanks for any help.
