Stuck on full revs
Posted: Sun May 12, 2013 7:36 pm
Out riding today and a couple of times the scoot stuck on full revs. first time at a roundabout dipped throttle but no joy first thought is a stuck throttle cable but second time coming up to junction same happened dropped throttle and held clutch in but engine was racing on full revs pulled up and turned off, engine died. Kick started and away we went then 50m later same happened, coasted to a stop and turned off ignition but engine kept going with ignition turned off had to turn fuel off and let it run to a stop screaming its little heart out.
Took air filter off then operated throttle cable to watch carb working as normal.
Going to change complete throttle cable but anyone any ideas if it might be something else.
Cheers Bruce
Cheers Bruce
