speedo magnet
Posted: Sun May 12, 2013 4:17 pm
by Gunny
I've got a Kosvo digital speedo fitted into my RD everything was working fine but ive lost the magnet off the front wheel so no speed reading , everything else working..
Are these chipped magnets or can i replace with any sort of magnet same size ?
Re: speedo magnet
Posted: Sun May 12, 2013 4:38 pm
by RICSPEED
any magnet should do it
Re: speedo magnet
Posted: Mon May 13, 2013 10:41 pm
by Gunny
cheers mate
Re: speedo magnet
Posted: Tue May 14, 2013 4:16 pm
by bizzly
Gunny wrote:I've got a Kosvo digital speedo fitted into my RD everything was working fine but ive lost the magnet off the front wheel so no speed reading , everything else working..
Glue it on as well
Re: speedo magnet
Posted: Tue May 14, 2013 5:02 pm
by soulsurfer
Bizzly, are you using the sensor with a SIP speedo? If so, did you use the SIP instructions or is more info needed as it refers to anther sheet? A mate seems to be struggling with his
Many thanks
Re: speedo magnet
Posted: Tue May 14, 2013 5:35 pm
by bizzly
soulsurfer wrote:Bizzly, are you using the sensor with a SIP speedo? If so, did you use the SIP instructions or is more info needed as it refers to anther sheet? A mate seems to be struggling with his
Many thanks
No mate, sorry..I'm using a koso speedo
Re: speedo magnet
Posted: Wed May 15, 2013 7:09 am
by rosscla
Is anybody using the magnet / sensor with a standard type disk hub?
If so, how have you mounted the sensor?
