Page 1 of 2
JL exhaust fitting
Posted: Sat May 11, 2013 3:38 pm
by dapper
Re: JL exhaust fitting
Posted: Sat May 11, 2013 3:54 pm
by bazman
Have you the altered jl exhaust made for the Avanti kit or the bog standard one?
Posted: Sat May 11, 2013 3:59 pm
by dapper
'twas sent to me by Martin (Corrado) who I bought the Avanti off, so should be the right one.
Posted: Sat May 11, 2013 4:03 pm
by bazman
Are you struggling with the two bolts which go through the nylon bobbins ?
Posted: Sat May 11, 2013 4:15 pm
by Andy Pickering
Have you bought the Avanti Franspeed ? if (as it sounds) you havent you will have this issue of bolts to close to fins and been unable to fit it correctly, you will have to make an alteration to the bracket (there is a picture on here of the alteration I will find it and post) you can grind out the fins to ease the bracket, BUT I WOULDNT, If you didnt remind Martin you needed the zorst to fit Avanti i doubt he would have remembered tbh, he gets dozens of requests everyday. I did btw buy the Avanti franspeed which Dan sourced for me from Andy Francis and fit the Avanti kit perfect.
Posted: Sat May 11, 2013 4:26 pm
by Adam_Winstone
Funnily enough, I've just been modifying an Avanti in such a manner so that I can fit my older JLs if I decide to in the future. However, as already stated, the revised Franspeed JLs fit with no modification required.
Adam
Posted: Sat May 11, 2013 4:39 pm
by diesel
My JL3 fits my Avanti with no alteration other than using thinner nuts. Its a bitch to fit, but it fits
Posted: Sat May 11, 2013 4:50 pm
by Andy Pickering
diesel wrote:My JL3 fits my Avanti with no alteration other than using thinner nuts. Its a bitch to fit, but it fits
lol, that comment is be fitting of the spike avatar with out a doubt
, it fits without alteration BUT
Posted: Sat May 11, 2013 4:59 pm
by Andy Pickering
Crickey finally found it, Canbus had this problem and this was his alteration:
Posted: Sun May 12, 2013 5:37 pm
by dapper
Martin confirmed it was a Franspeed Avanti Tour exhaust which I have now managed to fit without resorting to grinding down any fins. Had to grind down an 8mm nut to 5mm wide to fit between bracket and cylinder and what a fiddle that was trying to fit it on the bolt in such a narrow space, but all there now.
Also had to dremel off a bit of the scalloped out bracket so I could get the second nut on to secure to chaincase, but all fitted and solid.
