Page 1 of 2
Cyclone box with drops.
Posted: Thu May 09, 2013 9:26 pm
by 10 inch Terror
Hi all, I'm having an RB engine built and I'm going with the cyclone box. I'm using SX type drops on my scoot and the clutch lever ( Yamaha ) comes pretty close to the leg shield beading in 4th. I'm a bit concerned that it may actually touch the beading when I select 5th. Is anyone using the Cyclone box with drops that can confirm there's no problems? Cheers Pete.
Re: Cyclone box with drops.
Posted: Thu May 09, 2013 9:31 pm
by Grumpy225
From what I've read 1st and 5th are in the same spot as 1st and 4th. The gears are thinner so the overall travel on the bar end remains the same, just smaller movement between gears. Make sense?
Posted: Thu May 09, 2013 9:53 pm
by 10 inch Terror
Grumpy225 wrote:From what I've read 1st and 5th are in the same spot as 1st and 4th. The gears are thinner so the overall travel on the bar end remains the same, just smaller movement between gears. Make sense?
Yes, perfect sense, thanks very much.
Posted: Fri May 10, 2013 7:21 am
by Timbo
Not sure this is true, best to check with Riminni or someone that's got drops. My cyclone in 5th appears to be further down.
Posted: Fri May 10, 2013 2:11 pm
by RICSPEED
assuming you have sx type leggies then with drops it is very close
Posted: Fri May 10, 2013 2:44 pm
by Den 08
easy just don't turn left when in 5th (sorry couldn't resist :lol: )
but on a serious note could you not just move neutral setting say 5mm to you
on handlebar top even if you have clearance normally, will that give just a little more
if that makes sense maybe a solution.
i mean who actully looks at gearchange when riding.
i have seen peaple go into first and thought the gear cable must have snapped its so vertical!!!
Posted: Fri May 10, 2013 3:18 pm
by tony
Not sure how much room there is but it maybe possible to get a larger gear wheel turned up.
Posted: Fri May 10, 2013 6:27 pm
by 10 inch Terror
Yes standard type SX leg shields the Yamaha lever is pretty close to them in 4th. I like the lever because of the ease I can pull the clutch in with it, so don't really want to change it, plus the gear change is filed to match. I think I'll just see what it's like when the engine is fitted. If I have to mess about with 1st gear location and move it abit it's no biggie, I'm not a purist in that sense. Cheers all.
Posted: Fri May 10, 2013 9:45 pm
by immylam
hmmmm , I have a GP with drops and a 5 speed kit sitting on my shelf waiting to fit..... anyone know for sure?
Posted: Fri May 10, 2013 9:58 pm
by 10 inch Terror
immylam wrote:hmmmm , I have a GP with drops and a 5 speed kit sitting on my shelf waiting to fit..... anyone know for sure?
That was the point of this thread but, it seems nobody is using a Cyclone with drops or at least noboby thats seen this. I'm sure someone will come along and confirm either way.
