Wiring up a GS Ignition Switch.
Posted: Wed May 08, 2013 7:31 pm
Just one thing stands in my way of power wheeling up the street and annoying my neighbours: a GS ignition switch.
I have had a look at various wiring GS wiring diagrams, but i am none-the-wiser for it. I also spent 2 hours on my knees in the garage screwing the live from the stator into various terminals and noting down the other terminals that came live when you turned the key to different positions, but then i got bored.
I have fitted a 221cc malossi engine into a 152L2 frame and i have a simple PX to VBB loom, so none of the colours are anything like a GS loom. And there is no battery either.
Any way, i will make up the wires to the bulbs, horn, light switch etc from scraps of wire i have in the shed, so the colour of the wires is irrelevant really, all i need to know is:
1, which one do i plug the green 'Ignition Kill' wire from the CDi into. Does this just short the circuit to earth to kill the engine?
2, Where do i plug the 'main Yellow live' from the regulator, and which terminals do i use for side-lights, main feed to the Dip/Main Beam switch
3, i have 2 other lives from the regulator (one red and one black) that need to go to the horn and rear brake light, i presume?
The switch has 4 positions. I presume this is: 1: Ignition Off, 2: ignition on, but no Lights, 3: Ignition on & side Lights 4: Ignition on and Main Lights, just like a Lambretta GP / Series 3?
