bearings codes
Posted: Tue May 05, 2009 6:28 pm
by byron
following RinB's post on viton seals,
i need to get some bearings this week and wanted to go to local bearing supplier rather than have to order through a dealer and wait for the postie.
So what are the codes and sizes of the engine bearings ?
  • drive side
    mag side [GP200]
    gear cluster needle
    layshaft needle
    end plate
got the rear on order, and the clutch bush.
have I missed any ?
Re: bearings codes
Posted: Tue May 05, 2009 6:36 pm
by dapper
I get mine from either RS Components or Apollo Bearings. These are the sizes to quote
DRIVE SIDE 6305-2RS1 RS 285-1074
MAG HOUSING FAG £32.10 NU2205 GP APOLLO
MAG HOUSING NU205 LI/SX RS 285-1822
GEAR CLUSTER CASING 16-22-12 APOLLO
END PLATE 6004-2RSH RS 442-0010
END PLATE NEEDLE LAYSHAFT 20-24-10 APOLLO
REAR SPROCKET (or bronze bush) 24-28-10 x 2off APOLLO
FRONT WHEEL HUB 6201-2RSH RS 442-0183
Al the RS ones comes with double rubber seals. You have to remove the gearbox side one on the drive side bearing.
Re: bearings codes
Posted: Tue May 05, 2009 9:58 pm
by byron
thanks dapper. very useful
