long stroke or not
Posted: Tue May 07, 2013 10:35 am
following on from my gearing post previously,
im now considering ditching the long stroke and will keep my 57mm mec eur race crank in instead,
from the amount of forums posts etc, saying long stroking a malossi can be troublesome,
im inclinded to just use the crank i have,
im looking to keep the standard si 24 carb though and run it with a polini venturi,
will the malossi 210 perform alright on the motorway to get to rallies, with the standard carb with venturi on it,
i will look to get it dynoed to get it set up correctly,
plus then it leaves me the option to put a bigger carb on at a later date if necessary,
