whats the choices of rear hubs
Posted: Tue May 07, 2013 10:32 am
while my GP was running up on the dyno it was noticed that the hub runs out, its got a wobble on it, and now having ridden it more I have noticed that with light application of the rear brake you can feel it pulse, like a warped disc does.
going to look into it further, take it off, double check its all clean etc, but Im sure it is. if it was a problem with the cone fitting then I would expect to see it move left to right when viewed from the rear, but its doesnt, just up and down when viewed from the side
so whats the options, I have read not to use RAMP? ones
Im guessing that any genuine innocenti ones by now could be as bad or worse than mine
