API S2 Tank rubbers
Posted: Sat May 04, 2013 10:43 am
by gaz_powell
Still learning with this API S2
Dry build continues - was about to order series 1/2 tank rubbers and noticed that the bottom bracket on the frame has no holes to locate them
cant see any other way to locate hold them other then buying the gp
same for the ones to the rear again should i get gp type
cheers
gaz
Re: API S2 Tank rubbers
Posted: Wed Jul 17, 2013 7:59 pm
by goldeneye
have you sorted this Gaz, as young Karl in WWSC has broken two petrol taps on his API series 2, might have summat to do with this........ :?
Posted: Wed Jul 17, 2013 8:48 pm
by RICSPEED
when you say holes do you mean the oblong shaped trays that the rubber sits in ??
Posted: Thu Jul 18, 2013 5:05 pm
by gaz_powell
Ric
The API S2 does not have the italian style trays to lay the buffers in - they are more like GP (but not exactly the same) just flat
Before i looked I bought some S1/2 buffers and they had round locating bits on the bottom hence my comment about no holes in the frame bracket
I know have both S2 and GP - when tank comes back from welders i`ll see what works best
Having looked at it again i think it will be done with GP
Will let you all know the outcome wnen back from hols
Gaz
