Dzuss Nuts for rear runners
Posted: Fri May 03, 2013 12:06 pm
by Bilko
I'm finally putting some time aside to get work on my LI done. I'm looking at getting some Dzuss fasteners for the rear runners of my LI. Does anyone know if these would be the right size?
Dzuss Nuts
Re: Dzuss Nuts for rear runners
Posted: Fri May 03, 2013 5:45 pm
by 22/2
Thinking of doing the same, as I understand you need to add the total thickness of panel you are trying to secure (footboard +rubber washer)+ 7mm for the fastener and then buy the closest length of fastener, either rounding up or down.
Why are you looking at the rivet on type receptacle? won't the push on type work? Pro bolt have a massive selection
http://www.pro-bolt.com/ but costly (look quality though) may give you a better idea of what your looking for in the way of a fastener then look for best price, be aware the rolled type are allegedly rubbish, stick to the machined type they have a much more definite 'lock' on them,probably the best way to tell the difference is price, visit a few web sites and you'll see what i mean.
Good luck
Rich
Posted: Fri May 03, 2013 9:05 pm
by TED CRUD
javascript:;
Posted: Fri May 03, 2013 9:42 pm
by TED CRUD
http://www.ebay.co.uk/itm/140958000779? ... 1497.l2649
you can put them on top or underneath ,i was going to use them with skateboard tape on top instead of runners and or the the bridge mounting kit
Posted: Fri May 03, 2013 9:43 pm
by rosscla
TED CRUD wrote:javascript:;
C#
Posted: Fri May 03, 2013 11:52 pm
by Bilko
In my haste I wasn't looking at the fixings properly.
Thanks lads.
