stator flywheel problem
Posted: Mon Apr 29, 2013 10:42 pm
rebuilt engine back in frame and wired up - no spark so :-
1. Ran the triple earth - still no spark
it has new plug, cap and lead
2. Swopped CDI - still no spark - removed the green ignition no spark
3. Took flywheel (AF Lightened) and stator (Ducati - rebuilt by AF with a new LT coil and pick up) off
Put my spare genuine SIL stator and flywheel (just eyed up for timing as i only wanted to see if it would work) and bingo sparking like a good en !
4. Tested Ducati stator and all readings good well within the values quoted
before i stripped the bike it was running and starting okay - even though the wiring was in a right state and the pick up was cracked/damaged
Rebuilt engine using same casing, same crank (replaced SIL big end for NRB), same mag housing, new bearings and a new top end.
anyone experienced this with af flywheel and ducati stator ?
