Piston Ring gap
Posted: Tue May 05, 2009 7:21 am
I hope somebody can give me some input on the following.
I've just put together my new top end, its a cleaned up and tuned 225 Ali barrel with a steel liner. When I fitted the rings into the barrel straight out of the box the gap was 0.5mm. I have seen the figure of 0.05% of the bore as a clearance figure which would give 0.35mm.
So I have 3 main questions:
Will 0.5mm be OK to run with?
After I have run it in for 500 miles should I check this clearance again and if needed fit some more rings and this time try and gap them to 0.35mm.
If I fit some new rings at this stage how many miles would I need to run them in for.
