amal choke
Posted: Sun Apr 28, 2013 10:11 am
by DaveTomo
Can anyone confirm if there is a difference between an amal choke cable and a dellorto choke cable? got a delly 30 fitted at the moment,but going to be fitting an amal in the next week or 2.The amal has been machined to fit a delly manifold and the bellmouth has been machined for more panel clearance.I have asked knowledge (who I normally get my choke cables from) but he wasn't too sure,so to sum up ,will the delly choke cable fit an amal?
Re: amal choke
Posted: Sun Apr 28, 2013 1:52 pm
by byron
the end will fit, but you might have to play around with the outer casing length for the choke to operate correctly. I regularly swap between an Amal and a VHSA, and have a choke cable made to fit each.
