Tuned Ts1 head temp
MAB
Does anyone know what a ts1(tuned) head temp should run at approx as iam thinking along the lines of the Sip speedo with the temp gauge which apparently tops out at 250c 482 f
If iot doesn't sit within those limits then you will be in serious trouble :shock: My Avanti sits at about 160 if that helps.
C or f ?
fairspares
tuned rapido with large mb head 150 - 170c.
MAB
Cheers guys gives me a bit of an idea.
Thanks
Terrible Taff
Main scooter: Lambretta's & Vespa's
Location: 21 Meyricks, Coed Eva, Cwmbran, Torfaen, NP44 6TU
MAB wrote:Does anyone know what a ts1(tuned) head temp should run at approx as iam thinking along the lines of the Sip speedo with the temp gauge which apparently tops out at 250c 482 f
The SIP Speedo when set to KPH reads degrees C when set to MPH reads degrees F.
Also if you set wheel rpm to 1320 this will give you a very accurate speedo!
BR7ES Plug 210'C or 410'F
BR8ES Plug 240'C or 464'F
BR9ES Plug 270'C or 518'F
Hope the above data will help.
As Darrel has said the head & cowling need to be modified, on my Facebook profile in my photo albums you will find just how much is required to fit & mod cowling.
Ian
Ian T Frankland
Taffspeed Design Innovations
Mob: 07971 818693
Email: [email protected]
MAB
Cheers Ian thanks for that much appreciated that does help.
Just one more thing is it right that the speedo only reads up to 250 c I think I spotted it in Allstyles advert for them ?
Darrell Taylor
Main scooter: LAMBRETTA
been using an underplug cht on air cooled group 6 running a 10plug its showing around 370f to 390f
so the 250c 482 f sip unit should be within range
MAB
Cheers Darrell thats just what I was hoping for mate nice one.
Mark
    Users browsing this forum: Amazon [Bot] and 5 guests
