Page 1 of 3
CHT fitment on SIL speedo
Posted: Thu Apr 25, 2013 9:20 pm
by MAB
Sorry if this has already been asked but I can't find it .Regarding the temp lead can the threaded fitting that screws into the red spark plug ring be installed into one of the head fins with good results ?
Cheers
Re: CHT fitment on SIL speedo
Posted: Thu Apr 25, 2013 11:42 pm
by rosscla
is there a reason you can't use the plug ring?
Usually the best reading will be obtained from there, that said, I don't see why it couldn't work, the reading might be lower than under the plug tho'...
One you get to know what's normal for your motor you should be able to tell if things are heading in the wrong direction.
Posted: Fri Apr 26, 2013 8:20 am
by MAB
Thanks for the reply rosscla I've not ordered one just yet its just I was going to buy a temp gauge(which is important to me) and my speedo is next to useless so thought the Sip speedo will sort both out. Regarding the plug ring its just bits I have read on the forum and scootering really regarding issues but not sure who they got round it.
Cheers
Posted: Fri Apr 26, 2013 8:50 am
by Darrell Taylor
the plug ring needs the cowling and the head fin around the plug trimming away so extra work there and running the 2 wires together from plug and temp signal can cause interferance causing the unit to read erraticly so cable shielding may be needed
but as ross said once youve established a datum of whats normal temps or not you can work with it
Posted: Fri Apr 26, 2013 8:55 pm
by MAB
Cheers Darrell iam not one for messing about to much with the head Darrell do you think tapping one of the fins would be ok
Mark
Posted: Fri Apr 26, 2013 9:29 pm
by joespeed
MAB wrote:Cheers Darrell iam not one for messing about to much with the head Darrell do you think tapping one of the fins would be ok
Mark
thats a good idea,but get to know what is safe with your engine,
theres something in the fact that sip supplies a box full of the spark plug rings!!!
Posted: Fri Apr 26, 2013 9:30 pm
by MAB
Mmmm
Posted: Sun Apr 28, 2013 12:21 am
by sideout
I bolted one of mine to a fin on the head, works fine. However, I drilled a clearance hole as the thread is not a common Metric Coarse, I seem to recall I worked it out to be an American one.
Posted: Sun Apr 28, 2013 7:24 am
by coaster
sideout wrote:I bolted one of mine to a fin on the head, works fine. However, I drilled a clearance hole as the thread is not a common Metric Coarse, I seem to recall I worked it out to be an American one.
Which bit did you bolt to the head? the plug ring or did you bolt the screw in lead dirceclty to the head?
Posted: Sun Apr 28, 2013 4:31 pm
by MAB
Iam thinking it will be the threaded lead that screws in the plug ring .
