2 pack with powder coat - colour match
Posted: Wed Apr 24, 2013 11:04 pm
by mawso
Having some panels sprayed RAL9010 and want to get some other bits powder coated in same colour. Has anyone colour matched powder coat and paint before for their bike and how does it look when put side by side?
Re: 2 pack with powder coat - colour match
Posted: Thu Apr 25, 2013 5:18 am
by jazzyb
Av dun it a few times very good results I use mk motorcycles at shirebrook the guy who owns it ad scoots years ago so he understands and takes is time when blasting
Posted: Thu Apr 25, 2013 8:17 am
by mawso
Cheers Jazzy. Would you say the colours and finish were pretty close with the two then? That's why I'm sticking to RAL or BS colours as hope get the best match that way.
Congratulations on the SoulIISoul anniversary too...just seen you on breakfast TV lol!
Posted: Thu Apr 25, 2013 8:21 pm
by mr series 2
mawso wrote:Having some panels sprayed RAL9010 and want to get some other bits powder coated in same colour. Has anyone colour matched powder coat and paint before for their bike and how does it look when put side by side?
I had my frame & internals powder coated in Ral 1015 ivory at LSN in Castleford it matched the paint finish perfectly
Posted: Thu Apr 25, 2013 9:10 pm
by jazzyb
Hi mawso the match was great will post some pics at weekend
Posted: Thu Apr 25, 2013 9:19 pm
by GBCS
If they are both to the same RAL, the theory says they should be identical in colour.
However ... The sheen levels may not be the same, and that can make quite a difference when you put them side by side.
Posted: Fri Apr 26, 2013 8:29 am
by mawso
I'll be using either LSN or Midas Touch in Cass' too. They've both got some fancy finishes like candies and eerie-dess for custom jobs. Not doubting standard of finish with either of them.
Yeah the theory is it should match if it's the same code, but I'm a decorator and different brands versions of BS codes can vary a fair bit.
If you can post those pics up Jazzy that's be good. I know 10B15 as a colour quite well, it's one that I use with work a lot. Comes under Ivory, Soft White, Gardenia depending who's selling it. Be good to compare how the paintwork sits against powder.
Found out that satin finish powder coat is just un-lacquered, so I guess they can increase the sheen with more clear coat if I took panels in to give them a match.
Posted: Sun Apr 28, 2013 9:43 pm
by GBCS
Satin finish, or high gloss powder coats all come straight out of the box, and have nothing to do with clear coats.
Clear is normally an option, and not an essential part of the process.
Posted: Sun Apr 28, 2013 9:54 pm
by jason frost
Have the coating done then match the paint to it
