center stand spring.
Posted: Sun Apr 21, 2013 6:52 pm
by lcs99
do they do a slightly shorter spring heavy duty for a series 3, i have lots of play in the stand when it is up and my the looks of it the spring just needs to be shorter?
Re: center stand spring.
Posted: Sun Apr 21, 2013 11:30 pm
by Grumpy225
Never seen a shorter spring for the center stand. What usually happens is the stand bolts have gotten loose or the brackets are worn out and are allowing play in the stand.
It's a Lambretta and will shake its self apart unless you use locking hardware.
Posted: Mon Apr 22, 2013 11:22 pm
by coaster
Make sure the 'J' brackets haven't had the re-inforcing plates inserted as spacers, the brackets should be bolted directly to the frame. Using the plates as spacers is a dodge sometimes used when aftermarket stands sit too upright but then make the spring too short.
Posted: Tue Apr 23, 2013 5:28 am
by lcs99
Cheers guys, after investigation the centre struct weld has come away, so needs sorting, new weld, new j brackets, bolts etc. :)
