Cylinder packing plates
Posted: Tue Apr 16, 2013 6:51 pm
by Boreham
Does anyone have an 'idiots guide' to the advantages/ reasoning for fitting the packing plate at the base of the cylinder or at the head?
I am looking at a 60mm crank on a pinasco 177 kit, understood the need for the 1.5mm packer but on checking the options there is the std thicker base plate or a thicker head gasket (or even the MMW head machined for no additional head gasket)
Thoughts appreciated.
Re: Cylinder packing plates
Posted: Tue Apr 16, 2013 10:30 pm
by ducksta
put the kit together without the packer and see where the piston is compared to the ports then you will know either base or head
Posted: Wed Apr 17, 2013 8:21 pm
by GLscoot
I was told you also need to do a squish test, three strands of solder wire in a pyramid shape spanning the full diameter of the piston, turn the piston over by hand without the plug in. I think this is to make sure that the piston does not hit the cylinder head. I had a 1.5mm spacer on first then barrel and just to make sure i used a cardboard spacer 0.25mm between the head and barrel, but to be honest this is my first go at tuning a engine. Managed to port the casings myself to the Polini 180 kit, fairly easy job. In the winter I will port the carburettor. I hope this helps.
Posted: Thu Apr 18, 2013 7:27 am
by guygrrr
Essentially, packing the cylinder will give power at higer rpm's, loosening up a few more horses. where as packing the head allows power at lower rpm's giving more torque and better acceleration.
Posted: Thu Apr 18, 2013 6:59 pm
by Boreham
Cheers Guy, that was the info i needed, torquey tourer = thicker cylinder head gasket!
Posted: Wed Apr 24, 2013 8:57 am
by Norrie Bodge
Another option also...
Try a 1mm base packer & 0.5mm head gasket.
1.5 - 2mm on head squish
Keeps it torquey & regains a decent top-end too
