Page 1 of 6
RAPIDO 42 BHP to start with.
Posted: Tue Apr 16, 2013 5:05 pm
by fairspares
Been to dyno today for run on my new straightliners pro street class sprinter, Rapido 245cc 60 stroke 72 bore ,v force reed block , 39mm keihin pwk, standard franspeed race, mb head. Barrel porting, boost port and reed inlet by Ben@ AF Rayspeed, head work by Martin @ chiselspeed, casing/transfer porting and built by myself , no casing welding, unfortunatly on the third 3rd gear run one stator plate bolt came out and locked flywheel( had no tools to fix) if not it should have been around 45 bhp hopefully back to dyno thursday and out at East kirkby on sunday.
Re: RAPIDO 42 BHP to start with.
Posted: Tue Apr 16, 2013 6:01 pm
by WINTERMODEL150
Now that's nice
Posted: Tue Apr 16, 2013 6:26 pm
by Adam_Winstone
Nice
Does it vibrate like a good'un with those mounts in? I understand the fitting of them for a straightliner but they caused me grief when I decided to give them a go on my road bike. Not faulting it though... very nice.
Posted: Tue Apr 16, 2013 6:35 pm
by fairspares
yes it does vibrate "a good un" but hopefully it will all be over in 12 secs
Posted: Tue Apr 16, 2013 6:59 pm
by Dragsterlam
Great figures I always said rapidos are were its at!
fastest time with my Rapido 250 sprinter is 13.08 and I did not have have that sort of power
so you should see the 12's
Posted: Tue Apr 16, 2013 7:12 pm
by Adam_Winstone
Put in some good times and AF will find themselves selling a few more AF250 Rapidos
by Adam_Winstone
^... not suggesting that yours is anything like the off the shelf kit but it does show great potential.
Posted: Tue Apr 16, 2013 7:22 pm
by fairspares
The whole body work is fibreglass and carbon, the legshields are single layer fibreglass with the idea they will bend in slightly once speed increases, but keep it looking full-bodied. I really like the Rapido barrel , we have been working on this all over winter , it still has 1.5mm around the indian casing transferes ,and only a little work to clean barrel transferes, massive transferes are not needed , it comes down to exhaust timing / shape and how the inlet is flowed and shaped and casings to allow the flow to be drawn through as smoothly as possible, i wanted to try dyno without the reed stuffer and a higher revving pipe but that will be later in week now. ive took it out for a spin and its going to take some practise to keep the front down to get a good time, if i can manage that it should be quick.
Posted: Tue Apr 16, 2013 9:09 pm
by Muttley McLadd
That's a lovely colour. Is it green or yellow in daylight?
Posted: Tue Apr 16, 2013 10:34 pm
by Darrell Taylor
well done on the build looks great with a cracking result on the dyno too
best of luck for the weekend
