Brake Light Switch
Posted: Tue Apr 16, 2013 2:57 pm
by ArmandTanzarian
My widebody vespa has a rather awkward brake light switch arrangement. Basically its a universal switch that works by hooking a spring around the lever on the hub. As the cable pulls the lever, the spring operates the switch. It works but its all a bit Heath Robinson. Has anyone else come up with a more elegant solution?
Re: Brake Light Switch
Posted: Tue Apr 16, 2013 5:28 pm
by GLscoot
No not really, but can you not fit a brake switch into the front brake master cylinder. Similar to the PX. Or can you post a picture of the rear brake pedal, as you could fit one similar to the GS150, VBB, Sportique ect.
Posted: Tue Apr 16, 2013 7:46 pm
by ArmandTanzarian
The front has a switch in the master cylinder but I thought it would be a good idea to wire both. I'll take a picture.
Posted: Wed Apr 24, 2013 4:24 pm
by jonny snatchsniffer
you can get inline switches that clamp around the rear brake cable, a little less heath, but supposed to be a bit hilary (it swank), lots of old british stuff had to be retrofitted with a brake light, i also have to come up with a solution for this on a chop
