bearing race removal tool
Posted: Fri Apr 12, 2013 2:06 pm
by satans reject
Has anyone found a tool for removing the bearing race on your crank? Currently playing around with jubblie-clips, grinders and heat........ There's got to be a better way!
Re: bearing race removal tool
Posted: Fri Apr 12, 2013 2:32 pm
by DigDug
I used a Dremel on my last one - quite straightforward following Sticky's instructions.
Posted: Fri Apr 12, 2013 4:41 pm
by RICSPEED
yes look in stickys book .. the pics alone are better than any discription i could give
Posted: Fri Apr 19, 2013 2:51 pm
by ove
Lincs lambrettas do one, its very expensive if you're only going to use it a couple of times. He is only 25 miles from me so i popped in and he removed it free of charge. My crank was f@@ked, so he put collar straight on my new crank and 3k miles later and no problems. Top tool, russ top man but sometimes talks out of his arse!!
