Page 1 of 2
Bike grips
Posted: Sun May 03, 2009 11:11 pm
by sydduckett
Looking for a set of motorbike style grips in black for my Li. Eiter foam or rubber. Also looking for the chromed or polished end caps to fit the bars as well. Does anyone know the best ones and if pref ones that dont take too much fettling (he said hopfully)
Links please...
sef
Re: Bike grips
Posted: Sun May 03, 2009 11:23 pm
by Andy Pickering
TZR...MB developments
Re: Bike grips
Posted: Sun May 03, 2009 11:38 pm
by Muttley McLadd
'Superbike' grips I've always found to be excellent. They used to give them away on the front of one of the bike mags, but I can't remember which one.
There's some on
ebay all the time.
Re: Bike grips
Posted: Sun May 03, 2009 11:46 pm
by byron
Muttley McLadd wrote:'Superbike' grips I've always found to be excellent.
I tend to use them. Like all motorbike grips, they are different sizes, but they can both go on if made supple with boiling water first, and spraying lacquer or something onto the bar.
They come with plastic end plugs. I used Hope pushbike plugs, but when one fell out [after riding it before the silicone had gone off], i just replaced it with a Peroni bottle top...
Re: Bike grips
Posted: Mon May 04, 2009 9:18 am
by Dazza
I've used these too - very grippy, as said before you can get them on ebay and bar end weights too,
Re: Bike grips
Posted: Mon May 04, 2009 10:20 am
by shocky
im not knocking what some dealers charge for there grips but the TZR ones are in my experiance over priced i bought 3 sets for £7 a set last year ,another alternative is the renthol type
http://cgi.ebay.co.uk/Renthal-Road-Race ... 7C294%3A50 they are long though and reguire some sort of barend weight
total for grips, bar end weights and longer yamaha clutch lever was £15
Re: Bike grips
Posted: Mon May 04, 2009 6:24 pm
by sydduckett
Shocky, what are the grips on the other scoot, they look very nice? Yeah i need to get a dog leg clutch lever with ball end to match the one on my Scootsrs front disc set up. any idea where i can get said item. Pref one that sits flush with the housing.
sef
Re: Bike grips
Posted: Mon May 04, 2009 6:48 pm
by byron
sydduckett wrote:... Yeah i need to get a dog leg clutch lever with ball end to match the one on my Scootsrs front disc set up. any idea where i can get said item. Pref one that sits flush with the housing.
I use Spanish dogleg levers, as fitted to Servetas.
If they come black, the coating can be easily removed with thinners and then the lever polished
Re: Bike grips
Posted: Mon May 04, 2009 6:51 pm
by sydduckett
Do you know if the spanish servetta ones are a good fit, and all spanish levers the same? I have a series 3 Li
Ta
sef
Re: Bike grips
Posted: Mon May 04, 2009 6:57 pm
by shocky
the other grops are my dragster ones standard as far as i know unless someone knows differant the lever on the master cylinder isnt the yamaha one this is though i spaced it up with a small shim so its flush with the top this lever isnt a direct fit you have to do some cutting and grinding
