S2 struggling at higher revs
Posted: Fri Apr 05, 2013 4:27 pm
Hi
I have just finished my Li125 Series 2 and got it MOT'd and on the road. It's had a full resto and engine rebuild and it kicks off and ticks over well. It seems to struggle however when at full throttle. It sets off fine, accelerates and then loses power and begins chugging as the throttle is opened fully. I change gear and acceleration is again fine and same thing happens. It seems fine lower down the revs.
It is s2 125 engine with 150 top end (as far as I know) electronic ignition, standard 19mm Spaco carb jetted for 150 breathing through the airbox as standard. It has a standard s2 casa lambretta exhaust (although it was marked tv175)
Is it
a) a carb/ jetting/ fuel/ airflow issue- ie too much fuel or not enough getting through
b) something to do with the exhaust (are s2 tv175 exhausts different to 125/150 ones)
c) something else- timing, electrical, mechanical
d) the engine just naturally topping out and my expectations are too high for a standard engine/ carb/ exhaust etc.
All suggestions greatly received
Dan
Is it
Dan
