Position of bolt in buffers when fitted in Gp forks
Posted: Sun May 03, 2009 6:41 pm
by essexgp
I am in the process of fitting bolt in bottom buffers in my Gp forks to replace the ones that were in there that had been mullered. I have removed the old ones cleaned of the remains of the spot welds so now my question for you all is;
In what position do i fit the bolt in ones, ie distance back from the end of the fork or even better does anyone have a picture please.
thanks in anticipation :bouncing:
Re: Position of bolt in buffers when fitted in Gp forks
Posted: Sun May 03, 2009 7:41 pm
by carlos fandango
I can`t give you dimensions, but if you put you fork links in place. the buffers are positioned above and below the flats on the links, put the buffers in place. then a bit of guess work as to the exact position of the holes but that should put you in the right area. or of course you could measure / template some one elses li/ sx forks :lol:
Posted: Sun May 03, 2009 8:25 pm
by essexgp
Thanks for that, have drilled the holes and checked them against my other Gp forks and they seem in the right place :biggrin: :biggrin: :biggrin:
