Variotronic flywheel binding
Posted: Mon Apr 01, 2013 6:32 am
by bazabod_downunder
Just put on the variotronic flywheel when nut is hand tight & marginally tightened spins fine but when done up (& not to full torque) it is locked solid & seems to be fowling on the centre boss of the stator plate, initially I considered maybe the crank wasn't fully home but this is doubtful as had problems with the mag housing fowling on the crank which was solved by putting a slightly thicker gasket on.....anyone else had this problem or any ideas?
Baz
Re: Variotronic flywheel binding
Posted: Mon Apr 01, 2013 7:10 am
Problem solved....in my quest for ease I used allen bolts to secure the stator, this is what was causing to fouling....sorted :)
