Page 1 of 2
scorpion bobbins
Posted: Sun Mar 31, 2013 10:29 pm
by sydduckett
Anyone know where i can get the bobbins for a scorpion exhaust. the ones that go between the 2 plates where it ataches at the front of the chaincase.
Thanks
sef
Re: scorpion bobbins
Posted: Sun Mar 31, 2013 11:19 pm
by rosscla
Posted: Mon Apr 01, 2013 9:21 am
by shocky
try ebay search items like exhaust bobbins/cotton reels or try your local motocross shop
or even try scorpion direct there products are just about ok but there back up service seems second to none
demon tweeks have some good stuff as well often without SAT (SCOOTER ADDED TAX )
Posted: Mon Apr 01, 2013 7:47 pm
by tavspeed
i rang scorpion directly,and they popped some in the post,free of charge,top service,was a couple of years ago though.
Posted: Mon Apr 01, 2013 11:16 pm
by sydduckett
Not sure, i think that one is for the rear mount where it attaches to the bottom of the rear shock. Im looking for the 2 bobbins that sit between the metal plates on the front of the chaincase via the 2 larger studs. The pipe is 2nd hand and came with a bit of rubber between (see bodge), so im presuming they are going to be 2 nylon bobins ala jls, and franspeeds.
sef
Posted: Tue Apr 02, 2013 12:51 am
by rosscla
Ahhhh..sip do those
Posted: Tue Apr 02, 2013 8:44 am
by gaz_powell
x2 rubbers - i`ve just replaced some for a friend on his scorpion came from Welsh Scooter Part via ebay
they dont come with the steel insert tubes
i was surprised how expensive they where with the p+p
you will need to put them in boiling water to fit them into the bracket
Posted: Thu Apr 04, 2013 8:40 pm
by sydduckett
Cheers lads. im on it.
Posted: Thu Apr 04, 2013 9:20 pm
by fairspares
Posted: Fri Apr 05, 2013 1:26 am
by tha83
I use urethane skateboard truck bushings. Impervious to oil and gas, cheap, easy to get and work very well.
